logan55
Feb 04, 2023Follower
RBR750 dropping internet after 10 mins of every reboot
I am forced to use Comcast Xfi Modem to avoid paying extra for unlimited data. But I have Wifi turned off on the comcast modem and instead I am using 3 Orbi's in AP mode. The setup has been working...
Feb 04, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the RBR using a Dynamic or Static IP address configuration in AP mode? Static is recommended.
Is the Front LED on the RBR turning on PINK?
Be sure the ISP modems WiFi radios are fully disabled...
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
