tobiasjs
Jul 31, 2021Guide
RBR750 dropping WiFi connections every 10s in AP mode
[Originally posted in Orbi, cross posting as suggested there] Starting this morning, my RBR750 has been dropping WiFi connections every 10s. I factory reset it and everything was fine until I pu...
mcs123
Aug 31, 2021Tutor
tobiasjs did you find a solution to this? I have the same setup as you, Firewalla Gold as my router, and RBR750 in AP mode. Everything worked fine, then all of the sudden wifi just started dropping out every 8-10 seconds, the RBS won't stay connected to the RBR either... When I put the RBR back into Router mode the Wifi is rock solid and the RBS connects with no issue. I went back and forth several times, as soon as I put the RBR into AP mode wifi goes bonkers and nothing stays connected. Factory reset everything several times... same results.
Note: The RBR is on FW: V4.6.3.7_2.0.49
Aug 31, 2021Guru - Experienced User
Seeing similar issue here:
You might downgrade FW back to v3.
