tobiasjs
Jul 31, 2021Guide
RBR750 dropping WiFi connections every 10s in AP mode
[Originally posted in Orbi, cross posting as suggested there] Starting this morning, my RBR750 has been dropping WiFi connections every 10s. I factory reset it and everything was fine until I pu...
tobiasjs
Aug 31, 2021Guide
I haven't had the chance to try the firmware downgrade yet, but I'm reasonably confident that this is going to fix the issue. I've been living with the double NAT and the inability to distinguish devices at the firewall, which is not ideal.
Assuming it resolves the issue I'll collect logs before and after so that hopefully Netgear devs can fix the issue.
Aug 31, 2021Guru - Experienced User
I collected logs from mine last nite and sent them in. Hopefully next Fw update will fix this. I'm trying a factory reset on mine as well today after work and see if the problem continues. I presume it will. :smileyfrustrated:
