tobiasjs
Jul 31, 2021Guide
RBR750 dropping WiFi connections every 10s in AP mode
[Originally posted in Orbi, cross posting as suggested there] Starting this morning, my RBR750 has been dropping WiFi connections every 10s. I factory reset it and everything was fine until I pu...
tobiasjs
Aug 31, 2021Guide
I haven't had the chance to try the firmware downgrade yet, but I'm reasonably confident that this is going to fix the issue. I've been living with the double NAT and the inability to distinguish devices at the firewall, which is not ideal.
Assuming it resolves the issue I'll collect logs before and after so that hopefully Netgear devs can fix the issue.
Sep 05, 2021Guru - Experienced User
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact Blanca_O and DarrenM and send them a PM and ask for the beta.
Good Luck.
