ddfdfd
Feb 20, 2023Aspirant
RBR750 drops connection on only one laptop
I have an RBR750 with two RBS750 satellites. I have many connections (phones tablets, home gadgets, etc.) connected to the system. They are all working great and have no problems. I have one lapto...
michaelkenward
Feb 20, 2023Guru - Experienced User
ddfdfd wrote:
I have one laptop (HP) that intermittently drops it's signal, both wired and wirelessly.
What makes you suspect that your router is the cause rather than the laptop? When everything else works, that seems to be the most obvious candidate.
What happens when you use the laptop elsewhere?
Have you checked that you have the latest network drivers for your HP?
- ddfdfdFeb 20, 2023Aspirant
I'm not suggesting it's the router...I actually do think it's the laptop, but I was hoping there was some setting on the laptop that could be changed to improve compatibility with the Orbi. I was hoping someone else in the community experienced this as well.
- michaelkenwardFeb 20, 2023Guru - Experienced User
You are more likely to find help in HP users than in a Netgear community.
Like I said, Windows drivers.
The one setting in Windows that is known to cause issues is the type of network, public versus private.
Windows can block things on public networks, but that isn't usually something that kicks in after a while. It is always there.
