ronisack
Sep 27, 2020Follower
RBR750 ERR_CONNECTION_RESET
Hi, I m getting ERR_CONNECTION_RESET errors trying to access known good sites. How do I know they are good? I swich my wifi to use my mobel phone hot spot and have no issues. I have conntacted my ...
Mstrbig
Sep 28, 2020Master
ronisack wrote:Hi, I m getting ERR_CONNECTION_RESET errors trying to access known good sites. How do I know they are good? I swich my wifi to use my mobel phone hot spot and have no issues. I have conntacted my ISP and they have no issues with the sites. I also see many sites where I get this error flash for 2-3 seconds, then the site loads.
I have this with Chrome (primary) but also with Edge browser. It is on my computer (HP Tower), laptop (Surface) and my wife's computer. All are connected via WiFi.
I don't believe I have any special firewall or security on my systems, other than MS Defender.
I have rebooted moden, routers, computers and not success.
Any further trouble shooting or suggestions appreciated.
Ron
This is not usually caused by the router, unless you are using 3rd party DNS servers.
Try these suggestions:
perform website and browser/system check.
check the proxy settings.
clear the browser cache.
delete Winsock catalog entries.
