AMW1
Jul 05, 2022Aspirant
RBR750 Firmware 4.6.8.2_2.1.9 Slow Download
My orbi is running with a very slow download speed. Internet provider reported that they are providing internet without any issues of download speeds up to 600 mbps. I have had no issues for 1 year w...
Jul 05, 2022Guru - Experienced User
Are you connected wired or wirelessly to the system?
What are wired speed results with a wired PC and Ooklas installable speed test app?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Do you have Armor, Smart Parental Controls, or Traffic Meter enabled.
AMW1
I chose not to use the service provider's modem. I use a Netgear CM1000v2.
Orbi is wired to the router. Should get speeds up to 600 Mbps. Wiring in my laptop to the orbi isnt even giving me a connection.
Home size is 2200 square feet. Satellite is within 30 feet.
- AMW1Jul 05, 2022Aspirant
Wired does work now. 16 Mbps download 17.66 upload
