jnewbi
Nov 26, 2022Aspirant
rbr750 firmware update error
not a wifi expert. need help. RBR750 FW version 3.2.16.22, i know and i don't understand why it is so old, fails update. RBS both offline, totally. manual update RBR failed. after reading, t...
jnewbi
Nov 27, 2022Aspirant
yes, I can connect RBS by ethernet, update or reverse them. When I did this, they auto updated FW overnight and were offline the next morning. Pretty sure I tried updating the RBR but I will try again and report back. Sorry I cannot be more sure, tried so many things
THANK YOU SO MUCH FOR THE RECOMMENDATION!!!
tucsontico
Nov 27, 2022Virtuoso
OK. Sounds like you've gotten into a loop with the RBSs auto updating after you downgraded the firmware. I highly recommend updating to the most current firmware (Ver 4.6.11.1). This version will allow you to turn off the auto update feature. Here's a link to the firmware download page:
https://kb.netgear.com/000065215/RBR750-RBS750-Firmware-Version-4-6-11-1
As mentioned before, update the RBSs via ethernet first, then turn them off. Update the RBR next via an ethernet cable and using orbilogin.com (This will take you to the web GUI for your Orbi RBR.). Good Luck!
