oscarmtw
Feb 09, 2023Aspirant
RBR750 Firmware update fail
I can’t upgrade my router orbi RBR750 from 3.2.16.22_1.4.9 to any version. Upgrade failed both online and manual. My satellite orbi RBS750 can be upgraded and it is 4.6.9.11. Then, I can’...
Feb 09, 2023Guru - Experienced User
Can you manually update the FW on the RBS using the RBS web page?
Most current version of FW is here for both the RBS and RBR:
Use a wired PC and web browser connected to the RBS web page to send the updated FW file there.
Auto update doesn't correctly update the RBS first which it should, then the RBR lastly.
oscarmtw
RBS was upgraded but RBR can't be done.
- CrimpOnFeb 09, 2023Guru - Experienced User
If I read the download page correctly, the next firmware is v3.2.17.12.
(There was an issue with the original Orbi several years ago where one specific firmware had to be installed to permit later versions to install. I have never heard of the 750 having a similar situation, but..... I haven't come up with anything else, either.)
- oscarmtwFeb 09, 2023Aspirant
I tried just now and still failed to uprade to 3.2.17.12.
Has someone ever tried to upgrade via tftp? I tried this link How do I upload firmware to my NETGEAR router using TFTP on Apple macOS? | Answer | NETGEAR Support but still failed.
