jaymkay
Feb 10, 2023Aspirant
RBR750 firmware "update failed"
I updated my RBR750 today, Satellite upgrade worked but Router says update failed. How do I know why update failed and how to fix it ? So far Orbi system is working fine, but I'm worried it may stop ...
Feb 11, 2023Guru - Experienced User
Might just be displaying wrong because you are on the latest firmware. So there isn't anything to update.
If you happen to run into a failed update that isn't current, you can always manually update.
