jg2910
Nov 08, 2023Tutor
RBR750 Firmware Update Issues
hatI have an AX4200 system (RBR750) with 2 satellites and just went to see if there is new firmware available. I have auto firmware update enabled. I've encountered 2 different issues. One is t...
- Nov 08, 2023
What is that distance?
Some system may not be in the AU service data base so yours may not show up. Manual load is what I prefer anyways. MS Edge and a wired PC. I have both RBS web pages up and running. Send the RBS FW files to each, then as the progress circle begins, load the RBR FW file.
jg2910
Nov 08, 2023Tutor
Verizon ONT is I-211M-L.
The distance between the two RBS's to the RBR is the same, and with similar wall/obstructions.
I'll try the manual update, it's just very odd to me that the RBR is saying "No New Firmware Available" but the actual firmware file on the Netgear website appears to be several major revisions ahead.
Nov 08, 2023Guru - Experienced User
- jg2910Nov 08, 2023Tutor
Makes sense, the distance is probably 30 feet.
I've completed manual update on everything and it's working properly now. Thanks
- FURRYe38Nov 08, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- CrimpOnNov 08, 2023Guru - Experienced User
The term Automatic Update is (unfortunately) ambiguous (or at least not well-defined).
My understanding is that the concept is one of permission, to allow the customer a choice of:
- Only the customer is allowed to perform a firmware update, either by choosing the Update Firmware option in the Orbi app or Orbi web initerface or doing it manually, vs.
- Netgear has permission to push a firmware update whenever it wants to. The key here is that Netgear gets to decide when (and if) it will push an update.
This choice came about because customers have been adversely affected in the past when Netgear pushed a firmware update that did "bad things" to their systems. (One infamous case was when a firmware push locked customers out of the web interface and app and the only way to get access was a Factory Reset.)
Thus, owners of some Orbi models now have the option to allow/deny Netgear the ability to push an update.
Nothing about this infers that soon as an update is published on the support web site, Netgear will update systems to that new version quickly. Those of us who have the original RBR50 system, which does not offer the option to control automatic update, have noticed that the newest firmware was published in February, 2023 and Netgear has yet to push it to systems. As the Original Poster (OP) has remarked, the RBR750 firmware was posted months ago, and Netgear has yet to even let the Firmware Update process find it, much less push the firmware itself.
There is a mantra on the forum, "If it ain't broke, don't fix it." If this system appears to be performing as expected, some forum users would decide,"what good is updating the firmware going to do?" and simply wait. It's a personal decision.
- birdman222Nov 08, 2023Guide
I was going to ask....is it better do use auto update or do manual updates? Reading through some of the posts here, seems like many have problems while attempting a manual update. Thank you
Manual is recommended. I use manual ALL the time.
Use be sure to update using MS Edge or Firefox.
Use a wired PC.
Update the RBS first using there web pages to apply the FW.Update the RBR lastly.
After the system has been updated and is back to ready, Power OFF the ISP modem/ONT and Orbi router and satellites for 1 minute then back ON with the modem first, Orbi router next then all satellites lastly.
U use this same process. No issues seen when using it.
