Danielsoh
Jul 31, 2021Aspirant
RBR750 Firmware Update v4.6.3.7 disconnects my ISP
This morning I woke to find that my internet was down. On checking I saw that the ORBI router was flashing magenta and not connecting to my ISP. I thought my ISP was down until I plugged in the old ...
- Jul 31, 2021
Ah, gald you found the problem. Ya some new FW can cause some user configurations problems.
Glad it's working now. Please mark your thread as solved so others will know.
Enjoy.
Danielsoh
Tried that, didn't work.
However, I found that the VLAN Bridging was turned off! Switched it on and managed to get connected again. The firmware update must have changed that setting.
Thanks for replying FURRYe36
Jul 31, 2021Guru - Experienced User
Enjoy.
