Danielsoh
Jul 31, 2021Aspirant
RBR750 Firmware Update v4.6.3.7 disconnects my ISP
This morning I woke to find that my internet was down. On checking I saw that the ORBI router was flashing magenta and not connecting to my ISP. I thought my ISP was down until I plugged in the old ...
- Jul 31, 2021
Ah, gald you found the problem. Ya some new FW can cause some user configurations problems.
Glad it's working now. Please mark your thread as solved so others will know.
Enjoy.
RickDeNatale
Aug 18, 2021Aspirant
I'm seeing similar issues with my RBR750 since the update to v4.6.3.7
- first, the connection to/through the RBS750 became unstable and unreliable. My Apple TV in the bedroom near the satellite kept buffering and at times completely lost internet connectivity.
- then the RBR750 would "go red" and lose the internet. This happened when I was on with Apple support trying to solve a usb issue on a Mac mini, and they couldn't connect to screen share. I had to climb a ladder and power the router off and on again to get it to reboot. This happened again last night when I was hosting a zoom meeting.
I did connect the bedroom Apple TV via Ethernet.
Is the solution to downgrade the firmware?
I have gigabit fiber internet from Ting the only interface is the fiber to Ethernet adapter.
Aug 18, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP adapter and Orbi system been performed since last update?
Where is the RBR located that you have to climb a ladder to get to it?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Disable AX mode on the RBR.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
- RickDeNataleAug 19, 2021AspirantFirst off everything was working for over a year before Netgear pushed the firmware update.
The house is about 2500 sq ft. The router is on an upstairs wall which necessitated the stepladder.
Since nothing else changed, I doubt this is anything but a firmware issue.- FURRYe38Aug 19, 2021Guru - Experienced User
NG is aware of the problems and also recommended disabling AX mode as well and setting CTS to 2347.
Lets all hope the next FW update fixes this. Please be patient.
Since nothing else changed, I doubt this is anything but a firmware issue.- SideshowartAug 19, 2021Aspirant
Disabling the AX mode, Slows speeds to a crawl, makes the wifi virtually unusable. So its a trade off have Wifi that works great but disconnects 2x a day, or super low speeds but without interuption. Unleess I am missing something in settings that will help improve speed.
