Danielsoh
Jul 31, 2021Aspirant
RBR750 Firmware Update v4.6.3.7 disconnects my ISP
This morning I woke to find that my internet was down. On checking I saw that the ORBI router was flashing magenta and not connecting to my ISP. I thought my ISP was down until I plugged in the old ...
- Jul 31, 2021
Ah, gald you found the problem. Ya some new FW can cause some user configurations problems.
Glad it's working now. Please mark your thread as solved so others will know.
Enjoy.
MH135
Aug 13, 2021Tutor
V4.6.3.7 is the WORSE UPDATE EVER! Lowered my bandwidth for every device between 12-18 mbps. Called Comcast and they said nothing is wrong on their end. I cabled my laptop to do a speed test and sure enough, I got my 600+mbps but wifi, nope. I tried to rollback the firmware to the previous V3 but the satellite freezes at 99% and the router does not give you a "YES" button to proceed with the manual update.
I have tried resetting my Orbi RBR 750 and have nothing but the same issues. We need a fix ASAP!
FatBoy96
Aug 24, 2021Initiate
I second this comment. This is completely unacceptable performance. I purchased and installed the RBR750 and two RBS750 satellites at my daughter's rental house at college for her and her friends. Everything seemed to work great until I returned home. It's been disconnecting every single day. Need to reboot the modem and routers to re-establish the connections. I live 7 hours away, so I'm trying to talk her through everything. C'mon, Netgear, this is ridiculous! Fix it!!!!!
- SideshowartAug 24, 2021AspirantIve now tried every channel combination and various locations for the satellite but it has only gotten worse. Im trying a factory reset tomorrow. If that fails im disconnecting and hooking up my old nighthawk. It is a real shame when the product is great and worked fantastic but they fail to accept that the firmware failed and roll it back to a stable version, or at least give us the option to.
