Danielsoh
Jul 31, 2021Aspirant
RBR750 Firmware Update v4.6.3.7 disconnects my ISP
This morning I woke to find that my internet was down. On checking I saw that the ORBI router was flashing magenta and not connecting to my ISP. I thought my ISP was down until I plugged in the old ...
- Jul 31, 2021
Ah, gald you found the problem. Ya some new FW can cause some user configurations problems.
Glad it's working now. Please mark your thread as solved so others will know.
Enjoy.
FatBoy96
Aug 24, 2021Initiate
I second this comment. This is completely unacceptable performance. I purchased and installed the RBR750 and two RBS750 satellites at my daughter's rental house at college for her and her friends. Everything seemed to work great until I returned home. It's been disconnecting every single day. Need to reboot the modem and routers to re-establish the connections. I live 7 hours away, so I'm trying to talk her through everything. C'mon, Netgear, this is ridiculous! Fix it!!!!!
Sideshowart
Aug 24, 2021Aspirant
Ive now tried every channel combination and various locations for the satellite but it has only gotten worse. Im trying a factory reset tomorrow. If that fails im disconnecting and hooking up my old nighthawk. It is a real shame when the product is great and worked fantastic but they fail to accept that the firmware failed and roll it back to a stable version, or at least give us the option to.
