taxipom
Feb 10, 2023Initiate
RBR750 firmware update
Sorry for my naive question: the automatic installation fails on my Orbi, so I decided to install it manually. The instructions (https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my...
- Feb 10, 2023
the instructions say it can be a .img or .chk file.
It works well manually update. Use the .chk file.
Feb 10, 2023Guru - Experienced User
Just make sure you're using the right file for satellite and the correct for router. They're different
