taxipom
Feb 10, 2023Initiate
RBR750 firmware update
Sorry for my naive question: the automatic installation fails on my Orbi, so I decided to install it manually. The instructions (https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my...
- Feb 10, 2023
the instructions say it can be a .img or .chk file.
It works well manually update. Use the .chk file.
taxipom
I will try to do so.
For information, the instructions says that you can use either .chk or .img for the satellites, but that only mentions .img for the router, hence my confusion.
Thank you for you help.
Feb 10, 2023Guru - Experienced User
Should work fine.
So long as you're using the RBR file.
