MK2022
Oct 30, 2022Aspirant
RBR750 FW upgrade
1) Received an e-mail from NG that a new FW / security update is available for ORBI RBR750. 2) FW update using the web interface says "No New Firmware Available" for RBR750 [current FW: V4.6.9.11] a...
Oct 30, 2022Guru - Experienced User
Ya I saw that v.11.1 was available however were waiting on some feedback in regards to that and the support for it.
You can MANUALLY apply that version if you like. ALWAYS update the RBS first, then the RBR lastly.
Soon as I get some feedback from NG, will point me in the directly we need to go with this version.
If your system is working currently, then keep what loaded on it. "If it works, don't fix it."
