aussie2u
Jun 27, 2024Aspirant
RBR750 goes to magenta light every hour for 5minutes...
RBR750 bought last November goes offline, shows magenta light, goes back to working normal again in about 5minutes. This started a few weeks ago, potentially around the same time firmware was update...
aussie2u
Hi Furrye38, thanks for the quick response.
Firmware is 7.2.6.31
Spectrum Internet 500/20 plan.
Spectrum Modem reads: EN2251 Docsis 3.1 Hitron Technologies HWV:1D PC15
New Cat6 RJ45 - it's also been swapped during troubleshooting.
Home is 1500sqft tri level
Using 2 RBS750 Satellites with approx 20-25' distance (Router located on middle floor)
I did read in previous guides about that best practices method of starting things and did so a few times. The only devices I cannot completely turn off of course are IOT things like smart oven, washer, etc. Desktop and Laptop were off and started last when internet was re-established.
Jun 27, 2024Guru - Experienced User
Seen users with this version experiencing issues since it was released. May need to downgrade to v.21.
If the RBR front LED is turning PINK, usually means the ISP modem is not giving the RBR good services. I'd ask the ISP to check the signal line up to the modem to ensure it's working well. Have them look at logs during the time frames when you see the front LED on the RBR go pink to see if anything stands out from the modem.
For this size of home, having the RBR and two RBS deployed and too close to each other maybe too much.
I recommend that you turn OFF one RBS. Also might reduce the power on the RBR to 50% as well. Under Advanced Tab/Advanced Settings/Wireless Settings
Would only need to power off and back on the ISP modem, RBR and RBS.
- aussie2uJun 27, 2024Aspirant
Thanks for those tips - I'll try downgrading to .21 once I can get into it since it's refusing password and two security questions... I will try reducing power on satellites as well once I can get in.
Modem only has two lights, both stay on constant white while the router goes magenta. ISP says their logs indicate nothing, they have reset signal and re-provisioned the new modem, high signal strength.
- FURRYe38Jun 27, 2024Guru - Experienced User
đ
