fathobbit
Sep 06, 2021Star
RBR750 Guest network intermittent connection issues
Hi, I have purchased the RBR750 over 3 months ago and still working with netgear support to fix this issue but luck. Hence trying the community to see if anyone else has noticed this issue. ...
- Apr 02, 2022
I can confirm it was fixed after a week. đ
fathobbit
Sep 13, 2021Star
Support reached out to stating that I needed to download another firmware 4.6.3.16. I did ask them if they wanted me to factory reset and they said no. Even after this firmware update I'm still facing the same issue.
So is it fine for me to factor reset with this firmware even though they said no and try it out?
Thanks
Prem
Sep 14, 2021Guru - Experienced User
Factory reset. Walk thru the setup wizard. After you complete the setup wizard and don't enable Armor, pull the power adapters on the RBS first. Pull the power adapter on the RBR for 1 minute the plug back in. After the RBR is back online, plug in the RBS.
Keep in contact with NG support if this still continues to have problems with Guest Network.
- fathobbitSep 17, 2021Star
Did what you had mentioned, it seemed to work for a couple of days. Since I had daisy chained and used the default org wifi names, I now renamed my wifi, turned off my old Orbi and made this one the primary. Did the same thing again in terms turning off everything, starting up RBS and then RBR, etc but the issue started again.
So it worked for a day may be and then started again.
Thanks
- antSep 26, 2021Prodigy
Same issue here. I did notice if I turn off and on guest, then it will work well for a day or so. :(
