fathobbit
Sep 06, 2021Star
RBR750 Guest network intermittent connection issues
Hi, I have purchased the RBR750 over 3 months ago and still working with netgear support to fix this issue but luck. Hence trying the community to see if anyone else has noticed this issue. ...
- Apr 02, 2022
I can confirm it was fixed after a week. đ
KDSASSOC
Nov 07, 2021Guide
I think I'm going to do the same. Hopefully, Costco will still take it back even though its been 5 months. What version of Deco did you get Deco60? 90? Is it like Orbi where it has the same ssid for 2.4 and 5 and automatically connects the device to 2.4 if it can't do 5?
fathobbit
Nov 07, 2021Star
Costco will take it back, they are great. I pretty much did that. Basically I got the AX3600, comes with 3 units, so I replaced my 3 year Orbi system with these three units from Deco now, since the new Orbi did not work out. The only problem with the new deco compared to the Orbi, the number of ethernet ports are way less so I had to buy another ethernet switch. The ethernet speeds for some reason are slow but wifi speeds I get the maximum with the new Deco, so far been very happy, again, got this form Costco.
- KDSASSOCNov 07, 2021Guide
thanks for the info. i found the deco at costco that you got. i'll do the same.
- antNov 07, 2021Prodigy
KDSASSOC wrote:thanks for the info. i found the deco at costco that you got. i'll do the same.
Did Costco take your Orbi back without questions? Mine is about a year old. :(
i'm traveling for work this week so i won't be able to take it back until next week. but costco has been really good in the past about returns.
