fathobbit
Sep 06, 2021Star
RBR750 Guest network intermittent connection issues
Hi, I have purchased the RBR750 over 3 months ago and still working with netgear support to fix this issue but luck. Hence trying the community to see if anyone else has noticed this issue. ...
- Apr 01, 2022
I can confirm it was fixed after a week. đ
Feb 16, 2022Guru - Experienced User
PhantomPhreak53 wrote:
I'm having the exaxt same issue on the RBR850. Main network is working fine and no dropped Internet at all. I have like 30 devices on the main network and none of them ever complain about no Internet. My guest WiFi drops internet almost daily. I have to disconnect the WiFi from the device and reconnect to get Internet back. I work in IT and have tried everything to fix it. Can't get it to work and it's really frustrating. I wish Netgear would address this issue since it seems to be a common issue amongst multiple devices.
PhantomPhreak53
Feb 16, 2022Tutor
FURRYe38 wrote:What Firmware version is currently loaded?
PhantomPhreak53 wrote:I'm having the exaxt same issue on the RBR850. Main network is working fine and no dropped Internet at all. I have like 30 devices on the main network and none of them ever complain about no Internet. My guest WiFi drops internet almost daily. I have to disconnect the WiFi from the device and reconnect to get Internet back. I work in IT and have tried everything to fix it. Can't get it to work and it's really frustrating. I wish Netgear would address this issue since it seems to be a common issue amongst multiple devices.
Firmware Version
V4.6.3.16_2.0.51
I have tried factory resetting, reinstalling Firmware, removing guest WiFi and adding it back.
- FURRYe38Feb 16, 2022Guru - Experienced User
I would give this a try:
PhantomPhreak53 wrote:Firmware Version
V4.6.3.16_2.0.51I have tried factory resetting, reinstalling Firmware, removing guest WiFi and adding it back.
- PhantomPhreak53Feb 16, 2022Tutor
Is that an official Netgear release?
FURRYe38 wrote:I would give this a try:
- FURRYe38Feb 20, 2022Guru - Experienced User
Its only from NG.
