fathobbit
Sep 06, 2021Star
RBR750 Guest network intermittent connection issues
Hi, I have purchased the RBR750 over 3 months ago and still working with netgear support to fix this issue but luck. Hence trying the community to see if anyone else has noticed this issue. ...
- Apr 01, 2022
I can confirm it was fixed after a week. đ
Feb 20, 2022Guru - Experienced User
Would be worth try and see if the v5 FW works or not.
ant
Mar 11, 2022Prodigy
FURRYe38 wrote:Would be worth try and see if the v5 FW works or not.
Sure for anyone who wants to try it. That's not me since I don't have time. I will keep using the official v4.6.5.14_2.0.54 from Netgear's internal updater with this annoying issue. Also, my disconnections are random and varies on times. :(
