fathobbit
Sep 06, 2021Star
RBR750 Guest network intermittent connection issues
Hi, I have purchased the RBR750 over 3 months ago and still working with netgear support to fix this issue but luck. Hence trying the community to see if anyone else has noticed this issue. ...
- Apr 01, 2022
I can confirm it was fixed after a week. 😄
ant
Mar 24, 2022Prodigy
Oooh, firmwares came out finally but I am not ready to upgrade yet since people are using the Internet. I hope it finally fixed the guest network issue. Did anyone try it yet?
ant
Mar 25, 2022Prodigy
So far, the guest network issue seems to be fixed on my end after seven hours.
- FURRYe38Mar 25, 2022Guru - Experienced User
Good to hear.
- antApr 01, 2022Prodigy
- FURRYe38Apr 02, 2022Guru - Experienced User
Glad it'sworking. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
