fathobbit
Sep 06, 2021Star
RBR750 Guest network intermittent connection issues
Hi, I have purchased the RBR750 over 3 months ago and still working with netgear support to fix this issue but luck. Hence trying the community to see if anyone else has noticed this issue. ...
- Apr 01, 2022
I can confirm it was fixed after a week. 😄
ant
Mar 25, 2022Prodigy
So far, the guest network issue seems to be fixed on my end after seven hours.
Mar 25, 2022Guru - Experienced User
Good to hear.
- antApr 01, 2022Prodigy
- FURRYe38Apr 02, 2022Guru - Experienced User
Glad it'sworking. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- PeppersforpeaceApr 14, 2022Aspirant
I’ve had similar issues with my guest WiFi network for months on my RBR750. All my work equipment connects through it, Dell laptop, iPad and iPhone. Notice the issue more on the apple devices. The laptop is hardwired half the time into my one satellite node, so in that scenario it is not on the guest network anymore I guess.
Want to do the firmware update, Orbi app says I’m currently on V4.6.5.14, I hit check for update and it says nothing newer available…V4.6.7.14 is on the website though so it is not in anymore beta correct? Is my only option to to manually update via a laptop, or wait until the app sees it?
thanks!
