DennisMaxx
Oct 07, 2021Apprentice
RBR750 Guest Network visible while guest network is disabled
Hi, I have an issue I can't solve. I use Orbi RBR750 + 2 Satellites (RBS750). All devices have V4.6.3.16_20.51 installed. Once in a while my Devices are loosing WiFi Connection. When this happens, ...
Oct 08, 2021Guru - Experienced User
Also I don't see many people posting problems as you are seeing so you may want to try it as you seem to be the only one posting about it currently.
DennisMaxx
Oct 12, 2021Apprentice
So I have tried newest firmware. RBS is still showing "white LED blinking" and then turning to solid blue LED. Now I positioned my monitor next to the Orbi RBS to see when this happens, and it happens 4..5 times during 9h of working in my office.
So new firmware did not help regarding to this problem.
- FURRYe38Oct 12, 2021Guru - Experienced User
Did you manually install FW on the RBS first then RBR using a wired PC and web browser and then factory reset the system and setup from scratch?
So new firmware did not help regarding to this problem. - DennisMaxxOct 12, 2021ApprenticeInstalled via Netgear Orbi Interface. After that, saved backup file and did a factory reset of the whole system. Later, uploaded saved backup to have same settings as before
This time, manually install FW file on the RBS first then RBR using a wired PC and web browser and then factory reset the system and setup from scratch and do not apply a saved backup from file.
- DennisMaxxOct 21, 2021Apprentice
So, I needed some time for other things but I am back.
The Issue that my iPhone gets kicked out is still there. Can not fix this. I reinstalled FW manually as you told and powerd off the devices for several minutes after this. And startet new configuration of WiFi Network and so on but STILL have this problem. This really f.... me up. How can i go back to FW version 3.x ?
- FURRYe38Oct 21, 2021Guru - Experienced User
What happens if you go on and fully enable GN then turn around and disable it?
Does the GN SSID disappear when you turn OFF the RBR and RBS?
- DennisMaxxJan 06, 2022Apprentice
Sorry did not see your answer. Sure I tried this (turning GN ON and connect to it, then turn it OFF). I can see GN still every time when I have a drop out and the blue light on RBS is visible.
I asked in another thread for beta firmware...maybe this will help.
- FURRYe38Jan 06, 2022Guru - Experienced User
You'll need to contact NG support or a forum moderator and see if they can get you the FW that one user mentioned, If thats what they really got. I notice they haven't posted since they first mentioned that so not sure how credible that is since we don't see anything else.
Something else to try, do a full manual re-load of the FW file on the RBS and RBR. After the units are back to ready, use the ERASE function on the RBR and Press the reset button on the RBS for 15 seconds then release. When you see the front LED on the RBS start to blink WHITE, turn it OFF. Walk thru the setup wizard on the RBR and set it up fully. Once it's setup, take the RBS near or to same room as the RBR and turn ON the RBS and when the front LED slowly blinks WHITE, press the sync button on the RBS and on the RBR and let the RBS re-sync fully. I'd give a full 5 minutes. The front LED on the RBS should turn BLUE then turn OFF. Check the RBRs web page for RBS status and also log into the RBS web page as well. Once the front LED is OFF, turn the RBS off and place in remote location.
- DennisMaxxJan 10, 2022Apprentice
Hi furry,
I could install 4.6.7.5. exaclty after your suggestion (even waited for 20min). I still have these dropouts where my devices want to reconnect and loosing WiFi Signal. Exact in this moment I can see "Netgear_GUEST" WiFi. (In older Firmware I gave it a different name, but because I started from scratch, it is the default name).
Any thoughts?
- FURRYe38Jan 10, 2022Guru - Experienced User
Yes load the newer FW using the suggestion method in my last post.
- DennisMaxxJan 10, 2022ApprenticeThis was no question, I already did update last week and do have again same dropouts & see Guest Network despite I have switched it off
If you turn OFF the RBS, is the Guest Network still seen?
Did you power OFF the RBS and RBR for 1 minute or more after the FW was loaded?
Has a full on factory reset and setup from scratch been performed on the RBS and RBR?
- DennisMaxxJan 10, 2022ApprenticeDid not try do take RBS off because then I can not work, have to try on weekend
I did full factory reset and power off for 20min and yes, started from scratch! - FURRYe38Jan 10, 2022Guru - Experienced User
What broswer did you use to load the FW files?
Did you send the FW files to the RBS using the RBR web page or the RBSs web page?
- DennisMaxxJan 10, 2022ApprenticeBrowser was Safari on my MacBook.
When I selected RBS and "upload" it redirected me to RBS site, had to relogin there and than started uplaod. - FURRYe38Jan 10, 2022Guru - Experienced User
Ok. That should work.
Next time, you might try using FireFox browser to send the FW file.
Do you have Guest Network Broadcast disabled on the RBR prior to the FW update?
Are you pressing the sync buttons on the RBS and RBR when resyncing wirelessly after a reset?
- DennisMaxxJan 11, 2022Apprentice
Yes, GN was disabled before FW Update. As you said earlier, I switched GN ON and gave GN different name and switch off again. But no change in behavior
I did not press SYNC Button because my RBS (2x) find RBR without pressing. What is different when pressing SYNC button?
- FURRYe38Jan 11, 2022Guru - Experienced User
And if you power OFF the orbi system, the guest network SSID name disappears right?
So to confirm with just the RBR alone, and RBS turned OFF, you don't see the guest network SSID being broadcast?
Pressing the button may force a new configuration from the RBR to the RBS.
You might Reset the RBS then when the front LED starts to blink, turn them OFF. Then look at the RBRs web page and select Remove/Disconnect button next to each RBS on the RBRs web page. Do a full reboot of the RBR, then power ON the RBS one at a time. I recommend take both RBS to the same room as the RBR. Power ON one RBS and when the front LED startes to slowly, press the sync button on the RBS then RBR and let the RBS re-sync. Wait until the BLUE LED turns off. Connect to the RBSs web page and verify the status and that you see the SSID name listed and Security mode is set to WPA2. If you don't see these items, means the RBS is not syncing right. Something maybe wrong with the RBS.
If you get the RBS to fully sync, check the broadcast SSID for the guest network being listed at this point. If you don't see it after 5-10 minutes, power on next RBS and do same process.
- DennisMaxxJan 18, 2022Apprentice
Sure, if i power off, then GN disappears. Your steps to work this out did not work. I can not wait x Minutes for GN to appear, because it only appears when I have WIFI dropouts.
Now I could manage to make a screenshot. You can clearly see that GN ist disabled (not checked) but it shows up in "Wifis nearby". Sorry for GN-Name but I am fed up with this. Just before the moment of screenshot I changed GN Name and pressed "apply", you can See Netgear_GUEST & new SSID in parallel.
- FURRYe38Jan 18, 2022Guru - Experienced User
Are you using v4.6.7.5 FW on the RBR and RBS now?
V4.6.7.5_2.1.7 since it is available.
How was the FW file appled to the RBR and RBS? Thru the RBRs web page or directly to each units web page?
I presume using a web browser and using the RBS and RBRs web pages to send the files to each unit?
Only thing I can think of if to re-load the FW on the RBS and RBR again. RBS first, RBR lastly. I'd use MS Edge or Firefox. After they are re-loaded. Turn OFF the RBS and RBR for 1 minute. Leave the RBS OFF. Turn ON the RBR and after it comes to ready use the ERASE funtion on the RBR to factory reset it. Setup from scratch. Try setting manual channels 1 and 40. Leave CTS at default for now. Disable Guest Network. Leave the name default as well for now. Set Transmit power to 50%. Disable most of the Log options seen under Advanced Tab/Admin/Log. I would disable the logs for options you know that you don't normally use, i.e. VPN and blocked and accessed sites. Ensure NTP is set for your time zone and DST is enabled if your in the USA region. You can enable traffic meter or leave it off. I have mine enabled and No limit set. Avoid enableing Smart Parental Controls and Amror.
After the RBR configurations have been applied and the RBR rebooted, I'd bring the RBS to same room or near the RBR. Turn one RBS ON at a time. I would press the sync button on the RBS after the front LED starts to blink. Then on the RBR. Wait until the front LED turns BLUE then OFF. Watch the status on the RBRs web page. Log in to the RBS web page and make sure you don't see any Guest Network being displayed and the SSID name and Security mode is set on the RBS web page. Once done, turn off the RBS and do same process for next RBS.
Once RBS are fully synced wirelessly, power them off and put back in remote locations. You might try powering ON 1 RBS for now and see if the Guest Network reappears when something happens. If it happens again, swap out the RBS for the other RBS and see. If it continues to happen, then this is either a FW issue or a HW issue with your system that NG support will need to check into and see what can be done.
Can you tell me where I can find Firmware 3,x ? I would try going back to older FW first
NG download site however seen others try and the system re-updates back to v4 soon after.
You can try this:
- DennisMaxxJan 19, 2022Apprentice
So I gave it a last try today. Did EXACTLEY what you told two post earlier. Re-Installed firmware 4.6.7.x made an 30-30-30 Hard Reset on all devices and started from scratch without changing anything, so default WiFi name, default PW. After all Orbi were online and synced, I connected my Laptop via WiFi. And what could I see?? NETGEAR_Guest !!!!! Doublechecked instantly if GN is switched ON but it is SWITCHED OFF.
Just tried a view hours without changing anything, I got WiFi Dropouts again and again I could see GN available. I wrote GN password down and try to connect to GN, this worked, so I was online via GN despite GN is turned off.
I then opened a case to change hardware via Netgear support. They asked if I did 30-30-30 reset after updating and I confirmed. Looking forward HOW they will help me.
- FURRYe38Jan 19, 2022Guru - Experienced User
Ok keep on them about this. Seems that your unit maybe having problems. Might ask them for a RMA.
Have them help you capture Debug logs from the RBR AND RBS. IPAddress/debug.htm.
