stephp38's avatar
stephp38
RBR750 hardwired satelite losing connection
Hi everyone.
I have the RBR750 setup with two satelittes one of which is wifi the other is cat6 connected to the base station.
For a nearly a year it has been very very stable but now in the last two weeks the satelite that is cat6 wired keeps dropping off then reconnecting itself in anything from a couple of minutes to ten or so. I have just disconnected the cat6 to see if it is more stable on wifi mode.  Has anyone else had similar experiences, is it likely that one unit can develop faults? This my first mesh system so I'm new to any issues.
Thanks
Stephen
  • FURRYe38's avatar
    Try swapping locations with the other RBS to see if problem follows?
    • stephp38's avatar
      stephp38
      Thanks for reply. I actually unplugged the Cat6 and let it go wifi and it seems stable so guessing something's gone awry with my internal cat6 wiring. Going to check the contunity of them when I get a chance.
      Chhers
      • FURRYe38's avatar
