ducs4rs
Dec 30, 2021Tutor
RBR750 in AP Mode questions
I picked up an RBR750 with 2 satellites. The initial setup was painful but got it setup how I wanted after a day of trying. When I set the router up in AP mode I used a fixed IP address. On the landi...
scorn242
Dec 30, 2021Apprentice
Hi.
In order to change the IP config after an inital AP setup one has to re-run the wizard process and choose DHCP vs static IP, pick the NetBIOS name, etc.
In your initial static IP address config is the gateway IP address the same as the AP IP address or your router IP address?
Thanks,
S.
- ducs4rsDec 30, 2021Tutor
"is the gateway IP address the same as the AP IP address or your router IP address?" Answer is no.. My router is set to .254. I learned long ago not to use .1 since many routers default to .1 at initial setup.
How do I re-run the wizard, do I need to do a factory reset?
