ducs4rs
Dec 30, 2021Tutor
RBR750 in AP Mode questions
I picked up an RBR750 with 2 satellites. The initial setup was painful but got it setup how I wanted after a day of trying. When I set the router up in AP mode I used a fixed IP address. On the landi...
ducs4rs
Dec 30, 2021Tutor
"is the gateway IP address the same as the AP IP address or your router IP address?" Answer is no.. My router is set to .254. I learned long ago not to use .1 since many routers default to .1 at initial setup.
How do I re-run the wizard, do I need to do a factory reset?
scorn242
Dec 30, 2021Apprentice
I use an RBR850 but Ibelieve the GUI is the same. No need for factory reset just re do the wizard which can be found by looking at the screen shot below:
