DrDeaf
Mar 02, 2022Initiate
RBR750 in AP Mode Satellites won't connect wireless (only wired)
Hi All, I've been pulling my hair out for the last couple of hours. Here's the thing: I've switched internet providers. Previously I had the RBR750 working as a router in my network. Everyth...
DrDeaf
Hi,
I am running 4.6.5.14.
You?
Going to update them to the one i found posted on this forum, but that version is not posted on netgear support site.
So i'll have to find out if that is going to help.
Mar 02, 2022Guru - Experienced User
I believe I have 4.6.7.5 on mine but their not currently connected/running because i'm using a sxk30 right now.
You can try the newer firmware
make sure you install it to the satellites first and then the router. You might have to hardwire in the satellites to update them.
then do a factory reset/reintall (not from a backup).
