jbirdkberg
May 21, 2022Aspirant
RBR750 In AP Mode
System: 1) Edge device providing firewalling and DHCP. Also more granular reporting and network visibility than what ORBI can supply. 2) Switch between so some of the wired devices don't have to f...
May 22, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
How are the RBS connected to the RBR, wireless or wired?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- jbirdkbergMay 27, 2022Aspirant
Factory reset has been tried multiple times...
Size of house is irrelevant as it happens with the Router sitting on my desk where it is being configured.
The modem is Optimum's cable modem (Arris TM1602 which we've had for at least 5 years now), and even tried when I tested out TMobile's 5G modem.
Tried all different channels...
I have tried rebuilding from scratch (unfortunately with this firmware) without using any satellites. This starts to happen before I even connect one...
Tons of nearby neighbors, but it is the same amount as when I'm in router mode...
As mentioned, purchased a new one and as soon as I put into AP mode, it happened all over again so I returned the new one... It worked until it was upgraded, and there is no possibility to downgrade (the new router had the same issue).
Router mode everything works perfectly (took a while and that is where I have to leave it now until they fix it), but as soon as I go to AP mode, WiFi goes in and out. Doesn't matter what device (iPhones, iPads, Windows laptop, iMac, and MacBooks) as it is always the same result of the WiFi dropping. The SSID actually disappears, then reappears, then disappears, etc - around every 20 seconds or so... Tried some of the other oddball settings recommended from other threads, but nothing worked...
Giving up on these - unless there is a resolution, the next purchase won't be Netgear...
- FURRYe38May 27, 2022Guru - Experienced User
What is the mfr and model of this edge router?
What the IP address pool string your using on it? 192.168.1. something to something range?
Please give feedback on size of home and distances between the RBR and RBS as these are relevant in troubleshooting this.
Also if you have lots of neighbors you may have some wifi interferences.
You mentioned that you tried a different Orbi system and has same issues. Kind of points to something in your environment or configuration that causing problems.
I would start with the RBR and just 1 RBS to work with.
Ubiquiti EdgeRouter 4 - this acts as a firewall at the Edge and has some great statistics (that now I can't see because the Orbi has to remain in Router mode to work - it does work great as a router, but preferred AP mode for all of the control and stats from the EdgeRouter).
It is an 192.168 RFC1918 address space, but not 192.168.1.0/24. I had used several others, but I did try that one as well...
The distance has been anywhere from 50ft to 0ft (right next to it) to not even having the Satellite configured/connected. it doesn't have an issue with the Satellite. The issue is the WiFi is consistently dropping every 20 or so seconds.
That would make sense if the issue existed in Router mode (and I have had no WiFi issues for days in router mode).
Points to the firmware that I can't remove (as mentioned everything worked before I updated - my bad for that). Plus it worked WITHOUT a single issue for almost a year (it was set and forget) until the update around April of 2021. When I received the replacement RBR750, I upgraded to the same firmware (as I didn't know this would be it) and then experienced the same problem when I put it in AP mode. Also received same issue of inability to downgrade, as the option to select Yes was grayed out - returned it. And this was not the manual upgrade process for either, it was the auto (check for updates and let it roll).
I had tried without the Satellite altogether, and I only have 1 - the kit was RBK752...
By the way, I can perform auto updates (I believe there was 1 since the last one where I started experiencing issues), but I still can't manually (including the rollback).
Appreciate the feedback...
