jbirdkberg
May 21, 2022Aspirant
RBR750 In AP Mode
System: 1) Edge device providing firewalling and DHCP. Also more granular reporting and network visibility than what ORBI can supply. 2) Switch between so some of the wired devices don't have to f...
jbirdkberg
May 27, 2022Aspirant
Factory reset has been tried multiple times...
Size of house is irrelevant as it happens with the Router sitting on my desk where it is being configured.
The modem is Optimum's cable modem (Arris TM1602 which we've had for at least 5 years now), and even tried when I tested out TMobile's 5G modem.
Tried all different channels...
I have tried rebuilding from scratch (unfortunately with this firmware) without using any satellites. This starts to happen before I even connect one...
Tons of nearby neighbors, but it is the same amount as when I'm in router mode...
As mentioned, purchased a new one and as soon as I put into AP mode, it happened all over again so I returned the new one... It worked until it was upgraded, and there is no possibility to downgrade (the new router had the same issue).
Router mode everything works perfectly (took a while and that is where I have to leave it now until they fix it), but as soon as I go to AP mode, WiFi goes in and out. Doesn't matter what device (iPhones, iPads, Windows laptop, iMac, and MacBooks) as it is always the same result of the WiFi dropping. The SSID actually disappears, then reappears, then disappears, etc - around every 20 seconds or so... Tried some of the other oddball settings recommended from other threads, but nothing worked...
Giving up on these - unless there is a resolution, the next purchase won't be Netgear...
May 27, 2022Guru - Experienced User
What is the mfr and model of this edge router?
What the IP address pool string your using on it? 192.168.1. something to something range?
Please give feedback on size of home and distances between the RBR and RBS as these are relevant in troubleshooting this.
Also if you have lots of neighbors you may have some wifi interferences.
You mentioned that you tried a different Orbi system and has same issues. Kind of points to something in your environment or configuration that causing problems.
I would start with the RBR and just 1 RBS to work with.
