ddfdfd
Apr 19, 2023Aspirant
RBR750 Intermittant loss of signal
I have the RBR750 with 2 satellites. I do have 20 or devices connected, including 2 laptops. At times, the laptops, and laptops only, will lose the signal for a minute or two. One of the laptops i...
- Apr 24, 2023
How are the two satellites connected to the router?
(WiFi backhaul or 'wired' backhaul?)
Is there any sort of Ethernet switch between the router and laptop?
When all else has failed, the last resort is often to perform a Factory Reset on the router. I absolutely hate doing this because it takes me almost two hours to type in all of the configuration settings I have made to reserve IP addresses, give names to each device and change the device type and model numbers, set up OpenVPN, DDNS, etc. etc.
How much effort have you put into customizing the Orbi setup?
CrimpOn
Apr 19, 2023Guru - Experienced User
ddfdfd wrote:
At times, the laptops, and laptops only, will lose the signal for a minute or two. One of the laptops is even connected via Ethernet.
It would be useful to know more about what "lose the signal" involves, especially.more detail about the wired laptop
- Is this Windows? (10? 11?)
- Does the network symbol in the lower right change from the picture of a computer screen to a funny 'globe' symbol?
- Some notice pops up on the screen?
- Is some process interrupted? (streaming? video conference?)
- Do web pages not load?
