ddfdfd
Apr 19, 2023Aspirant
RBR750 Intermittant loss of signal
I have the RBR750 with 2 satellites. I do have 20 or devices connected, including 2 laptops. At times, the laptops, and laptops only, will lose the signal for a minute or two. One of the laptops i...
- Apr 24, 2023
How are the two satellites connected to the router?
(WiFi backhaul or 'wired' backhaul?)
Is there any sort of Ethernet switch between the router and laptop?
When all else has failed, the last resort is often to perform a Factory Reset on the router. I absolutely hate doing this because it takes me almost two hours to type in all of the configuration settings I have made to reserve IP addresses, give names to each device and change the device type and model numbers, set up OpenVPN, DDNS, etc. etc.
How much effort have you put into customizing the Orbi setup?
ddfdfd
Thanks FURRYe38 and CrimpOn,
I think these are all of the answers to your questions:
xfinity modem (in bridge mode model CGM4331COM
Orbi router RBR750 Firmware - V4.6.14.3_2.3.12
Good quality CAT6 cable
distance is not an issue...wired is 20-25 ft, wireless is 10 ft
Can't see where to check the channels
noise from neighbors is not an issue, plus it's happening on the wired laptop
Armor, Smart Parental Controls or Circle, Traffic Meter all disabled
Windows 11 Home
It always appears that it is connected to the network, no globe appears
Some notice pops up on the screen? NO
Is some process interrupted? (streaming? video conference?) NO
Do web pages not load? they do not load, first I get the dns error, then no internet error
Apr 19, 2023Guru - Experienced User
distance is not an issue...wired is 20-25 ft, wireless is 10 ft <Is this the distance between the RBR and RBS? If so, These distnaces are TOO close. 30 feet to start with in distance between the RBR and RBS. Regardless if the RBS are wireless or ethernet connected to the RBR.
Can't see where to check the channels< On the RBRs web page under Basic/Wireless Settings
Armor, Smart Parental Controls or Circle, Traffic Meter all disabledWindows 11 Home <Be sure all wireless or ethernet adatper drivers are up to date from the adapter mfr chip set web site.
It always appears that it is connected to the network, no globe appears< Globe?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
