jswhite69
Jul 22, 2021Follower
RBR750, iPhone and iPad will not stay connected. Switch to guest, all is good
Hello, I have an Orbi RBR750 system (selected RBR50 above as I couldn't find the 750 option) with 2 satellites (RBS750). About 1 month ago, I noticed my iPhone and iPad would not conntect automati...
Jul 22, 2021Guru - Experienced User
What model iphones and pads do you have?
What iOS versions are being used on these devices?
Try setting CTS values to to 2347 under Advanced Tab/Advanced Settings/Wireless Settings.
What is the distance between the router and satellite(s)📡? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor enabled?
