angryCOMMguy
May 10, 2021Aspirant
RBR750 IPv6 not advertising prefix destination
About a week ago IPv6 quit connecting on all my devices to the Internet. After doing some research I've found that my router has the correct WAN and LAN IPs/Prefixes that are given by DHCP from my I...
angryCOMMguy
Playing around more I'm able to get IPv6 to work on my LAN devices now by enabling "Pass Through" instead of "Auto-Detect/DHCP" though it assigns addresses from the ISP's WAN and not from the /56 LAN that they had assigned me to use. So I can get IPv6 to work but it just seams that something is off/wrong having to enable pass through, would this be an issue with the ISP?
- angryCOMMguyMay 10, 2021Aspirant
Running in "Pass Through" only a few machines running Windows are getting IPv6 access/addresses other devices like my LG TVs are not able to get an IPv6 address. Very strange.
- FURRYe38May 10, 2021Guru - Experienced User
If this has been working, even after a FW update, possible something with the ISP may have changed or changed and caused something in FW to break. You should contact NG support and file a support ticket:
So danced between agents at Netgear and no one really knew what to do. I have to say their tech support, even the premium service, is atrocious and unhelpful. We finally got to the point that their going to replace the router, so hoping that's the fix and that the router I have is a dud. Will update this thread when new router arrives and is set up.
