conductor
Sep 26, 2022Aspirant
RBR750 issue: 50% speed slowdown
I've owned several Netgear routers, starting with WNDR3700. I purchased the RBR50 once the firmware began to get some good reviews, and it worked well. To keep up with the introduction of WiFi 6 I pu...
- Sep 29, 2022
I have a reconditioned/refurbished/refreshed RBR750 on the way, due to arrive tomorrow. Thanks to the three of you who responded. Too bad no one has a solution for lightning strikes. 😉
I will mark this case "Solved," since the more I have thought about it the more I have concluded that lightning is not a scapegoat but the cause.
conductor
I also would think that hardware breakdown is rare. I've not experienced such a thing with the 7 or so routers I own/have owned. There are 3 speedtests: (1) in the Orbi software, (2) on a Firefox browser on "the last Intel iMac," and (3) on the iPhone 13 Speedtest app. They all agree.
The modem is a Motorola MB8600 Docsis 3.1. There is no "double NAT," and even if there were it would be for all three routers in the comparison.
Thanks for your comments.
ekhalil
Sep 26, 2022Master
Are the satellites wired paired to Orbi router or wireless? What other wired devices do you have in your network?
- conductorSep 27, 2022Aspirant
Two satellites use the 5G wireless backhaul. Those connections are stable and have not varied before or after the slowdown.
The Orbi router has wired connections to the iMac, a Synology Diskstation, and an Apple TV. All but the iMac were OFF for testing.
One satellite has a wired connection to another computer that is OFF for testing and, in fact, ON only occasionally. The other satellite has no wired connections.
Thanks for the questions.
- FURRYe38Sep 27, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, SPC, Traffic Meter. Have any of these been enabled before?Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
Current firmware 4.6.8.5 with 4.6.9.11 downloaded and ready to be reinstalled. "Reinstalled," because that was the firmware installed sometime after July 4 -- the only change I could isolate between the good Orbi speed test of July 4 and recent testing by various means that showed the 50% slowdown. My testing of the two firmware versions showed no difference in speed between the two firmware versions.
Satellites are within 30 feet. There was no change to the physical configuration between RBR and the two RBSs before the slowdown was noticed.
Home size about 1500 square feet. Router very near the middle and satellites on either end. Again, this configuration and placement are consistent and have worked well historically with both RBR50 and RBR750 ... until sometime after July 4, the date of the last test showing speed slightly over 200 Mbps (download).
Channels are Auto and 48, respectively. I tried 44 -- no change. And again, these and the others you mention have not varied before/after slowdown. About 10 wireless networks visible beyond mine. No change from before, though people do tend to change the names from time to time.
No Armor or Traffic Meter on. I have no idea what you mean by "SPC," which may be a firmware feature for the RBR750 but not the RBR50, which is currently running. I'll set up the 750 and let you know if I find it. The other configuration items are not variable between good and bad testing.
Reboots have been numerous, both modem and router, in proper sequence. I have not reconfigured settings from scratch recently but rather used a configuration saved before the slowdown occurred.
While I appreciate -- no, really! -- your thorough questioning, I want to keep emphasizing that I did not mess with the configuration except to turn off UPnP (security issue). I cannot think of any change in software or physical configuration to blame for the slowdown. I am tempted to say there absolutely had been none, but in fact I did turn off UPnP and at some point about 4 or 5 months ago -- well before the slowdown -- I reconfigured the router from scratch, using notes I had made from the previous setup for LAN address reservation (2 devices that need a permanent IP), email setup, and port forwarding for my external access (SFTP).
Are you hinting that after a firmware update, one should factory reset the router and configure it from scratch?? Or only that I might try that because of this issue? While I performed a factory reset and then logged in and did the initial security questions, I used a saved .cfg file (from well before the slowdown).
Hope I've addressed everything.
