conductor's avatar
conductor
RBR750 issue: 50% speed slowdown
I've owned several Netgear routers, starting with WNDR3700. I purchased the RBR50 once the firmware began to get some good reviews, and it worked well. To keep up with the introduction of WiFi 6 I pu...
  • conductor's avatar
    conductor
    Sep 29, 2022
    I have a reconditioned/refurbished/refreshed RBR750 on the way, due to arrive tomorrow. Thanks to the three of you who responded. Too bad no one has a solution for lightning strikes. šŸ˜‰
    I will mark this case "Solved," since the more I have thought about it the more I have concluded that lightning is not a scapegoat but the cause.
