Tolken501
May 12, 2022Aspirant
RBR750 keeps going offline and won’t reconnect
RBR750 firmware V4.6.5.14 Modem Cm1000. All hardwired equipment has internet service but the Orbi stays pink and won’t reconnect even after several reboots.
May 12, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
if the front LED is PINK this usually means the modem isn't giving ISP services or the cable in between the modem and router could be bad. CAT6 is recommended. https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- Tolken501May 12, 2022AspirantYes several shutdown and reboots were performed in sequence recommended and also with different cat 6 cables it’s still offline flashing pink
