tony3425
Apr 09, 2022Aspirant
RBR750 Lagging When Downloading
I purchased the AX4200 RBR750 a year ago from Costco. I have run into a problem where anytime I start a download on my computer(which is hardwired into main unit), Other devices will lag, whether it...
Apr 10, 2022Guru - Experienced User
what firmware is on the router?
what modem/gateway is it connected to?
You have 400mbps service but is the hardwired in computer maxing out that connection when its downloading? if it is, you would expect your other devices to lag as it'd be saturating your bandwidth.
As soon as its done downloading, your lag/issues resolve?
- tony3425Apr 10, 2022Aspirant
Current firmware version is v4.6.5.14
The modem is Spectrum's Arris SB8200 Reb 6 Docsis 3.1
How do I know if it's maxing out the bandwidth? Let me also add, that if my son tries downloading something on his xbox, it will do the same thing to her stream.
If these tasks are maxing out the bandwidth, are there settings within the router to prevent this? I would assume that having 400mbps speed should prevent this from happening, but I guess not? Again, thank you for any help with this.
- FURRYe38Apr 11, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What wireless devices are you using and have connected when your downloading and streaming?
