Eric_In_FL
Feb 09, 2022Aspirant
RBR750 LAN IP keeps resetting to default
I've configured my RBR750 to hand out IP address in the 10.0.0.x range, and the router IP to be 10.0.0.1. However, after a few recent power outages (I know, I know ... a UPS is on its way from Amazon...
Feb 10, 2022Guru - Experienced User
You might review this:
- Eric_In_FLFeb 10, 2022Aspirant
The ISP gateway is a Pace/Arris 5268AC. There is an ONT out in the garage, but it's only connections are the fiber in from the street and ethernet to the 5268.
Yes, I have done a factory reset and setup from scratch since the last time the firmware was updated. I'll (hopefully) be updating to the new firmware you linked to over the weekend.
- CrimpOnFeb 10, 2022Guru - Experienced UserIs the Pace required? As in does it provide phone or TV service? If not, I would try connecting the Orbi directly to the Pace.
Yes, the Pace Gateway is required for TV service.
- FURRYe38Feb 11, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would give #2 a try. Try settting the RBRs IP address to 192.168.0.1 and LAN IP address pool range from 192.168.0.100 thru .200.
- Eric_In_FLFeb 15, 2022Aspirant
I upgraded to the 4.6.7.5 firmware that was linked upthread over the weekend. When I got to the "unplug power" part of the FW update, I plugged my RBR750 into a UPS when I re-plugged. Had to set the Orbi IP address (it had defaulted back to 192.168.1.1 again), this time I tried 192.168.0.1 rather than 10.0.0.1. The RBR750 hasn't rebooted itself since then, so I don't know if the firmware upgrade (or the UPS) fixed the issue, I guess only time will tell.
Re the AT&T gateway/Double NAT - The gateway wifi is disabled, and the Orbi was on the DMZ+ port already (Option #2), but it's nice to have confirmation that I set it up the "least bad" way :)
