Eric_In_FL
Feb 09, 2022Aspirant
RBR750 LAN IP keeps resetting to default
I've configured my RBR750 to hand out IP address in the 10.0.0.x range, and the router IP to be 10.0.0.1. However, after a few recent power outages (I know, I know ... a UPS is on its way from Amazon...
Eric_In_FL
Feb 10, 2022Aspirant
The ISP gateway is a Pace/Arris 5268AC. There is an ONT out in the garage, but it's only connections are the fiber in from the street and ethernet to the 5268.
Yes, I have done a factory reset and setup from scratch since the last time the firmware was updated. I'll (hopefully) be updating to the new firmware you linked to over the weekend.
CrimpOn
Feb 10, 2022Guru - Experienced User
Is the Pace required? As in does it provide phone or TV service? If not, I would try connecting the Orbi directly to the Pace.
- Eric_In_FLFeb 10, 2022Aspirant
Yes, the Pace Gateway is required for TV service.
