moonie-man
Sep 15, 2021Aspirant
RBR750 large downloads choke all other connections
I have an iMac Pro I work from home on, and my wife works on her laptop in another room connected to the satellite unit. I'm finding that when I start a big download (100s of MB or more) specificall...
moonie-man
Sep 21, 2021Aspirant
After much diagnosis, I finally found out that my ISP did not set the modem/router into bridged mode as they claimed. So I set their router into bridged mode, and now the RBR750 is holding the public-facing IP instead of the modem's NAT-ed address. This seems to have solved the issue I was having.
- FURRYe38Sep 21, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
