ottostar
Jun 10, 2022Aspirant
RBR750 light keeps flashing white and wifi network is not visible
the light on my router keeps flashing white, the wifi network is not visible to the device but in the GUI shows as OK. The satellites are not showing as connected either.
Jun 17, 2022Guru - Experienced User
What brand and model modem or optical network terminal (ONT) are you using?
What CAT# lan cable do you have between the RBR and modem/ONT? CAT6 is recommended.
Factory reset and setup from scratch with out loading the backup from file.
Power off both RBR and ISP Modem/ONT for 1 minute then back ON with the modem/ONT then RBR.
ottostar
Jun 19, 2022Aspirant
I have tried setting up the devices from scratch, no luck with that. The base starts blinking white as soon as the Wifi config is saved and the satellites fail to be added.
The wired devices connected to the router have internet connectivity. Any idea why the wireless networks would not be available?
- FURRYe38Jun 20, 2022Guru - Experienced User
Try try updating FW as well to v.2 seen this this forum...
