ottostar
Jun 10, 2022Aspirant
RBR750 light keeps flashing white and wifi network is not visible
the light on my router keeps flashing white, the wifi network is not visible to the device but in the GUI shows as OK. The satellites are not showing as connected either.
ottostar
Jun 25, 2022Aspirant
Thank you all for the replies and the suggestions.
I would like to emphasis ONLY THE WIFI is NOT working, meaning the WiFi networks main and guest is not showing up in the list of available WiFi networks.
ALL devices connected to the RJ45 ports have internet access, for that reason I am positive the issue is not with the cable or modem.
Did any of you experience the same issue?
- FURRYe38Jun 25, 2022Guru - Experienced User
So please give feedback to the question presented...
What brand and model modem or optical network terminal (ONT) are you using?
What CAT# lan cable do you have between the RBR and modem/ONT? CAT6 is recommended.
Power off both RBR and ISP Modem/ONT for 1 minute then back ON with the modem/ONT then RBR.
Try try updating FW as well to v.5 seen this this forum...
My 7 series has been online since yesterday, aside mysterious reboots, wifi has been ONLINE always.
