kbrumbaugh's avatar
kbrumbaugh
RBR750 Local NAT Loopback Not Working
I am having issues with NAT Loopback not working with my RBR750 when accessing a resource on my local LAN.
I've reviewed this thread (Orbi NAT Hairpinning/Loopback Not Working - NETGEAR Communities) but it did not provide an answer to my issue.
I running a Synology NAS with DDNS and Quick-Connect Configured. Port forwarding has been configured and appears to be working correctly to access the Management Console on port 5001, when outside my local network. However, if attempt to connect by the FQDN or Synology Quick-Connect address inside the LAN network it is not reachable.
My configuration:
  • Xfinity Modem in Bridge Mode
  • RBR750 setup in Routing Mode
    • WAN port of Router is the ISP issued public IP address which does match and resolve to the DDNS entry
    • Gateway is a public Xfinity address
    • DNS Server Configuration:
      • 75.75.75.75
      • 75.75.76.76
    • Firmware version: 4.6.14.3
As noted port forwarding appears to be working correctly as the resource is available outside my local network. While on the local network I am able to access the resource using the local private IP address, but via the host name assigned in DDNS or by the Synology Quick-Connect ID.
Any thoughts or suggestions on resolving the resolution and routing of this resource?
  • FURRYe38's avatar
    Do you have any RBS? If so, what model RBS do you have?
    Has this worked for you at all in this configuration? Or is this the first time setting this up?
    Have you tried the ISP modem in router mode and the RBR in AP mode to see if loopback works at the modem?
    • kbrumbaugh's avatar
      kbrumbaugh
      I do have two RBS750 satellites on the mesh. I have not attempted to set up the modem in routing mode as it is an Xfinity provided router and to my knowledge and research understand Xfinity blocks local NAT loopback if serving as the router.
      • FURRYe38's avatar
        Ok, was wondering about the RBS as your still on older FW and newer v7 FW doesn't work with RBS350 series. The RBS750 series is good with v7 FW.  Could try updating to v.21 FW and see if this changes anything.
        Wondering if the ISP could block any router for NAT loopback...not sure here.
    • CrimpOn's avatar
      CrimpOn
      Totally "my bad" about the 350.
      Is DDNS set up
      • On the Synology, or
      • On the Orbi router?
      I find the documentation about Synology Quick Connect confusing. Specifically, the comment that Quick Connect "works better" if ports 5000, 5001, and 6690 are forwarded through the customer router.
      https://kb.synology.com/en-global/DSM/help/DSM/AdminCenter/connection_quickconnect?version=7
      What the heck?  Does Quick Connect function through port forwarding or is it like so many Internet of Things connections (using an IP connection established by the Synology connecting to a Cloud service)?
        kbrumbaugh
        DDNS is configured on the Synology.
        Quickconnect appears to punch a whole like other IOT devices. Because Synology serves as a proxy for this service, I typically keep it turned off for security. However, I've enabled it to try to assist with troubleshooting this more general DDNS resolution and routing issue.
        Synology_QuickConnect_White_Paper_enu.pdf
  • CrimpOn's avatar
    CrimpOn
    The question about specific model of satellites was because Netgear created a "cheaper package" that included one RBR750 router and two RBS350 satellites.  While the RBR750 now has updated firmware, the RBS350 firmware has not been updated and updating the router will make it incompatible with the satellites.  Users who purchased that package have been through very unpleasant efforts to get their systems working again.
    • FURRYe38's avatar
      Glad this user doesn't have to worry about that here.
