kbrumbaugh
Jul 09, 2024Aspirant
RBR750 Local NAT Loopback Not Working
I am having issues with NAT Loopback not working with my RBR750 when accessing a resource on my local LAN. I've reviewed this thread (Orbi NAT Hairpinning/Loopback Not Working - NETGEAR Communities)...
kbrumbaugh
Sorry I omitted that I did also try to use the WAN IP:Port in the URL on the browser. I receive the same result as if I was trying to use the FQDN. On Edge I receive the following:
Hmmm… can't reach this page
xxxxx refused to connect.
ERR_CONNECTION_REFUSED
In regard to comment about DNS, I have my DHCP scope defined to include the LAN side IP address of the RBR750. In other words, I have the RBR configured to serve as the DNS for my local clients.
CrimpOn
Jul 09, 2024Guru - Experienced User
Would it be convenient to try this with other browsers?
"refused to connect" implies (to me) that NAT-loopback redirected the connection attempt (https to port 5001 ?) to the Synology but that the Synology rejected the connection. If NAT-loopback is not working, I would expect the error to be "IP address not found"
- kbrumbaughJul 09, 2024Aspirant
The port is correct as it is the same port used when accessing from outside. To make this even more confusing, I'm now not sure where to direct my attention after preforming some additional tests while connected to local LAN from different devices I am able to connect with my iPhone using Safari.
iPhone (https:\\ddns_fqdn:5001)
Safari - Site resolves and loads using the DDNS address (Regular and Private)
Edge - Error (Regular and Incognito)
Firefox - Error (Regular and Private)
Chrome - Error (Regular and Incognito)
Windows PC (https:\\ddns_fqdn:5001)
Mac (https:\\ddns_fqdn:5001)
Safari - Error
- CrimpOnJul 09, 2024Guru - Experienced User
Thanks for taking the time to test several browsers. Is the reported error consistent across all of these tests?
It may take me some time to set up an experiment with a 750 router (to verify that NAT-loopback functions on the 750 as it does on my primary RBR50.)
When users report problems with inexpensive devices (smart switches, cameras, etc.) if they cost under $30 I purchase one from Amazon to replicate their problem personally. A Synology NAS is a bit more of an investment.
On the bright side, is it correct to assume that this is now an intellectual curiosity. i.e.
- Web access from the local LAN to the LAN IP works correctly?
- Internet access to the DDNS URL works correctly?
- What is not working is using NAT-loopback to use the DDNS URL while connected to the local LAN?
I have lost track of whether Synology Quick Connected is working.
- kbrumbaughJul 10, 2024Aspirant
- Web access from the local LAN to the LAN IP works correctly? Yes this works
- Internet access to the DDNS URL works correctly? Yes this works
- What is not working is using NAT-loopback to use the DDNS URL while connected to the local LAN? Mixed
I've now also run netcat on my mac and even though port 5001 is set up with port forwarding along with 443, 80, and 5000, it is coming up as "Connection Refused", while succeeding with port 443, 80, and 5000.
I've also run a separate port scan utility from inside my network to the DDNS address and it shows 5001 as closed but 443, 80, and 5000 are open. However, if I run that same scan from whatsmyip.com/port-scanner it shows all 4 ports as being open.
Quickconnect is working from within the local network at this time. It is just the DDNS access that isn't working to port 5001.
As it appears general aspects of port forwarding are working and it may be somewhat a curiosity now why 5001 is being refused from most devices and browsers while the other ports are successful, my issue is still not resolved, in being able to reliably use a consistent method to access the port from mobile devices when I am on LAN and off LAN.
- CrimpOnJul 10, 2024Guru - Experienced User
(sorry to remain confused.) Does access from the local LAN to the public IP address of the router (not the DDNS URL) work on port 5001? If it does, then hardcoding the public IP address would enable a consistent method until the dynamic IP address changes. In my case, the public IP remains stable for extended periods of time. If not, then this is not a workable solution.
That TP-Link article about NAT-loopback had a strange comment at the end about FTP:
https://community.tp-link.com/en/home/stories/detail/1726
This leads me to wonder if there is perhaps a conflict with port 5001. Ports 80, 443, and 5000 are doing NAT-loopback with no issues, but port 5001 is failing. Would it be possible, at least temporarily, to change the https port number on the Synology from 5001 to "something else".
CrimpOn the public IP address elicits the same behavior as that of trying to connect via DDNS. Also I just attempted to change the port from 5001 to 5010 which produced the same results as 5001.
What a mess! Port 443 is https, and it works. (but, not connecting to a Synology box?)
I am guessing that this network is not set up to capture packets between the RBR750 and Synology?
(my preference is to use a managed switch to mirror the device Ethernet port to a computer running Wireshark.)
Another method is to open the Orbi debug page (http://orbilogin.net/debug.htm
Scroll toward the bottom of the page.
Enable LAN/WAN Packet Capture.
Start Capture.
Perform the experiment.
Save the capture, which will store a zip file on the computer.
The zip file includes two packet captures: wan.pcap (for the WAN port) and lan.pcap (for devices wired to the LAN ports of the router).
Opening lan.pcap with an app for pcap files, such as tcpdump, libPCAP, WinPCAP, NPCAP, Zeek, Snort, Suricata, Wireshark
The point would be to verify:
- That after passing through the Orbi router, the connection is delivered to the Synology NAS on port 5001, and
- Exactly what the Synology returns that is being displayed by the router as an error message.
- CrimpOnJul 11, 2024Guru - Experienced User
Did an experiment:
Connected RBR750 running firmware v7.2.6.31 to the primary Orbi network. This router is assigned 192.168.1.71 to its WAN address.
Created port forwarding rules on the RBR750
- Port 5000 to LAN IP 10.0.0.2 (a Windows computer)
- Port 5001 to LAN IP 10.0.0.2 (the Windows computer)
Installed Rebex (free) web server on this Windows computer. Defined the listening ports as
- Port 5000 for http
- Port 5001 for https
Started the web server and told Windows to allow both private and public access through the firewall.
On the primary network, opened Edge web browser to https://192.168.1.71:5001 After the usual complaints about security, the Rebex web page opened. Thus, the RBR750 forward connection from the WAN port to the internal web server.
Connected a Chromebook to the RBR750 WiFi network and opened Chrome browser to https://192.168.1.71:5001 (the WAN i.e. "public" IP of the RBR750). After the usual security complaint, the Rebex web page opened. Thus, NAT-loopback on the RBR750 sent the connection to the Rebex web server.
It would be a chore to set up a DNS entry to test this loopback issue and we've already seen that using the URL and the hardcoded IP address behave the same.
So, what is different? I am testing against a plain vanilla web server and the goal is to connect to a Synology NAS, which I do not have to experiment with.
It is beginning to appear that the only consistent method of connecting with this Synology NAS is to use Synology Quick Connect. Perhaps not the most efficient method in a network utilization sense, but consistent in both internet and LAN scenarios.
- kbrumbaughJul 11, 2024Aspirant
CrimpOn thank you for all your effort in setting up the test environment to validate my configuration. This is a real curiosity and as you noted quickconnect may be the best answer.
CrimpOn Out of curiosity, if you still have the Rebex web server enabled, will it allow you to create a second site that uses port 80 and port 443 while running the initial test site on 5000 and 5001, thus having port forwarding to 4 listening ports on the same server?
My Synology runs a number of different services with 443 and 80 supporting Web Services, while 5000 and 5001 support the management UI and a few other file, audio and surveillance services. I'm now curios if there may be something with the SSL associations between 443 and 5001.
Well, darn. This Rebex free web server goes with the last port mentioned in the configuration file. Does not appear to be capable of listening to multiple ports. I've tried listing 5001 and then 443 (it goes with 443) and 443 first then 5001 (it goes with 5001).
I'll see what other free web servers are available. (but not optimistic)
Does Synology have an active user community? While our focus is on the Netgear Orbi, Synology users may have experience with NAT-loopback with other routers.
