kbrumbaugh
Jul 09, 2024Aspirant
RBR750 Local NAT Loopback Not Working
I am having issues with NAT Loopback not working with my RBR750 when accessing a resource on my local LAN. I've reviewed this thread (Orbi NAT Hairpinning/Loopback Not Working - NETGEAR Communities)...
kbrumbaugh
Jul 11, 2024Aspirant
CrimpOn Out of curiosity, if you still have the Rebex web server enabled, will it allow you to create a second site that uses port 80 and port 443 while running the initial test site on 5000 and 5001, thus having port forwarding to 4 listening ports on the same server?
My Synology runs a number of different services with 443 and 80 supporting Web Services, while 5000 and 5001 support the management UI and a few other file, audio and surveillance services. I'm now curios if there may be something with the SSL associations between 443 and 5001.
CrimpOn
Jul 11, 2024Guru - Experienced User
Well, darn. This Rebex free web server goes with the last port mentioned in the configuration file. Does not appear to be capable of listening to multiple ports. I've tried listing 5001 and then 443 (it goes with 443) and 443 first then 5001 (it goes with 5001).
I'll see what other free web servers are available. (but not optimistic)
Does Synology have an active user community? While our focus is on the Netgear Orbi, Synology users may have experience with NAT-loopback with other routers.
