kbrumbaugh
Jul 09, 2024Aspirant
RBR750 Local NAT Loopback Not Working
I am having issues with NAT Loopback not working with my RBR750 when accessing a resource on my local LAN. I've reviewed this thread (Orbi NAT Hairpinning/Loopback Not Working - NETGEAR Communities)...
CrimpOn
Jul 13, 2024Guru - Experienced User
Might be useful to know what firmware is currently installed on the 750 router.
Message 1 mentioned firmware 4.6.14.3
Message 5 mentioned "will update firmware tonight"
But, I do not see in the conversation where that was done (or not). Did I miss it?
Would very much like to look at the data packets between the router and the Synology when a device attempts to connect to port 5001. That would be a major undertaking (sigh) involving
- Starting packet capture on the debug page.
- Attempting to connect. (I would do a web http (port 80), web https (port 443), and then a management connection (port 5001).
- Save the packet capture.
- On the computer, open the debug zip file and extract lan.pcap
- Save lan.pcap somewhere. (I do not think the forum software allows binary or zip files to be attached to messages)
- Send a link to this file, either on this conversation or a private message.
kbrumbaugh
Jul 14, 2024Aspirant
The satellites and router were both on 4.6.14.3. I've since managed to complete the updates of the satellites to V7.2.6.31. I'm now working on getting the router updated but also have an ongoing backup job running across the network. So although I know I should get all three devices on the same firmware as soon as possible, am reluctant to start it while the backup is running.
