fb894
Nov 19, 2020Guide
RBR750 lose internet connection daily
I have an ORBI RBR750 with 2 satelites. Modem is arris TM1602 my old router from my isp is disconnected. Firmware is the latest on router and satelites. I loose my internet connection atleas...
fb894
Nov 21, 2020Guide
Firmware is V3.2.16.6_1.4.4 On router and both satelites
i changed the cat 5 to a cat 6
Armor has been off
Have not tried router without satelites yet.
ISP supplies line to house which then uses a splitter for entire house. which is only splitter to the router.
I see the link provided recommends a FW update to the old FW last used. Is that possibly the solution?
Nov 21, 2020Guru - Experienced User
Try this newer version of FW and see if this helps:
https://community.netgear.com/t5/Orbi-AX/New-Firmware-Out-Today/m-p/2005684/highlight/true#M9268
If not, revert to the older version as mentioned in the other link.
I would have the ISP sure the signal to the modem is good. Splitters can cause problems.
- FURRYe38Nov 21, 2020Guru - Experienced User
Well, skip the new FW, thats for the 8 series Orbi..sorry about that. I don't see one yet for the 7 series.
